davdelct75
Sep 04, 2015Follower
iSCSI with armOS5.3.11 Readynas NV+ v2
Hi all, I have one Readynas NV+ v2 (RND4000v2), armOS5.3.11 , and i would like to create an iSCSI target. I cannot see any menu regarding iSCSI function. I cannot upgrade to OS6 (I find a lot of gui...
- Sep 04, 2015
Regrettably the nv+ v2 firmware doesn't support iSCSI (and you can't load OS6 on the platform either)
So if you need this I think you will need a new NAS.
Sep 04, 2015Guru - Experienced User
- mdgm-ntgrSep 04, 2015NETGEAR Employee Retired
What were you wanting to use iSCSI for anyway?
If you do want to use iSCSI then I'd recommend getting a new business class ReadyNAS such as the RN314.
