euhr
Jun 22, 2018Aspirant
Issue with expanding storage in Netgear Ready NAS 4312S
Hello,
We have a Netgear ReadyNAS 4312s with 72T storage (12 * 8TB disks in RAID6). Six months back, we bought a 24-bay Netgear expansion chassis and populated it with 5 8TB disks. We had to create...
Jun 26, 2018Guru - Experienced User
euhr wrote:We are running 6.8.0.
Thx. The current options for flexraid were introduced in 6.7 (a couple of months before 6.8.0 came out).
I'd wait for mdgm-ntgr's guidance on whether you should try upgrading firmware now.
If you aren't desperately in need of space, you might consider waiting until after you get the backup NAS set up before you do a lot of troubleshooting.
euhr
Jun 26, 2018Aspirant
Okay, I will wait for his guidance then.
The backup NAS is going to take some time to catch up, so we might not be able to wait for that to finish and also the backup NAS is not actually a drop in replacement for this primary NAS (we have internal limitations).
AFAICT, this should be a very straight forward thing that should work out of the box... The fact that it isn't working means that I am not doing something right or there is a software bug.
- StephenBJun 26, 2018Guru - Experienced User
I agree it should have worked out of the box - it could be an already-fixed bug that wasn’t listed in the release notes.
However, I don’t think it’s wise to have a single volume span both chassis. I’d have created two volumes, one for each.
- euhrJun 26, 2018Aspirant
Agreed. I will check the feasablity of upgrading the firmware to the latest version (needs a bit of downtime and I will have to co-ordinate internally for the same).
In the meanwhile, is it possible to ask internally once if this is a known issue which is fixed in the newer firmware versions?>> However, I don’t think it’s wise to have a single volume span both chassis. I’d have created two volumes, one for each.
I can't recollect why we decided against it. Couple of things that I could think of are:- We thought separate RAID groups would give us a bit more high availablity (and I believe we didn't have a choice to expand RAID group 1 and hence we had to go for the RAID Group 2)
- Creating new volumes would mean creating new partitions and mount them on all machines (we are still using fstab...) and its an added overhead to manage.Any disadvantages of a single volume?
- StephenBJun 27, 2018Guru - Experienced User
Though your RAID groups don't span both chassis, concatenating them into one file system increases the chance of file system corruption - because the expansion raid group can get out of step with the main chassis raid group. Lost writes are more likely to affect multiple disks in the expansion chassis.
For instance, lost writes to the expansion disks could be the result of
- glitches on the SAS connection between the two chassis
- power loss that hits the expansion chassis first
- failure of the expansion unit but not the main chassis
- slower write speeds on the expansion chassis, due to bandwidth limitations on the SAS connection.
Agreed. I will check the feasablity of upgrading the firmware to the latest version (needs a bit of downtime and I will have to co-ordinate internally for the same).I'd recommend waiting on mdgm-ntgr or another Netgear mod for advice on whether to do the firmware upgrade now, or whether it should wait until your expansion issue is resolved.
- euhrJun 29, 2018Aspirant
Noted on your points on having separate volumes.
I am planning to do the upgrade tomorrow. We have to debug this further if that doesn't help. - euhrJul 02, 2018Aspirant
Over the weekend, upgraded to firmware 6.9.3 after which the Expand button worked.
The data sync is in progress and hopefully everything should be good once that is done.
Thanks everyone for your help.
