B52hbuff
Oct 25, 2011Aspirant
iTunes 10.5 fix posted and now removed...
viewtopic.php?f=22&t=58261 The original thread is locked. I'm curious to know what it means: *** Please hold off on installing this add-on -- it looks like we'll need to release it. Sorry for the i...
mdgm-ntgr
Oct 26, 2011NETGEAR Employee Retired
New 1.0.3 update works fine for me on both sparc and x86!
If you installed an older version of the update and the new update doesn't work for you (e.g. you can't access Firefly web admin page) install the latest firmware over the top of itself (or try a firmware re-install) then install the add-on update again. This worked for me on my NV+ (a Sparc ReadyNAS)
Edit: I did add a /etc/mt-daapd.conf file on my Sparc NAS before installing the latest version of the update but I would think that would be automatically recreated if it's found to be not present when doing the OS/firmware re-install.
