B52hbuff
Oct 25, 2011Aspirant
iTunes 10.5 fix posted and now removed...
viewtopic.php?f=22&t=58261
The original thread is locked. I'm curious to know what it means:
*** Please hold off on installing this add-on -- it looks like we'll need to release it. Sorry for the inconvenience. ***
Also curious to know if there is a thread we can subscribe to in order to get notification when fix is available. Can you comment on whether this is a real fix or a temporary workaround?
Thanks for your hard work...
- handoAspirantConfirmed working with 1.0.3 update on ReadyNas Ultra 4, itunes 10.5. Thanks devs.
- emmakAspirantAnd working again! Thanks mdgm for the helpful advice on reinstalling the firmware...And Thanks devs
- nohareAspirantThis works for me!! :D
Since upgrading to iTunes 10.5 like everyone else my firefly server was incompatible. I removed the FireFly Add-on altogether and waited for a fix. When it came out I installed it and tweaked the mt-daapd.conf file to point at my correct media folders and all seems to work well (fingers crossed it stays that way!!)
Thanks to all those who helped with fixing this..... :wink:
I'm running 4.1.8 on a ReadyNAS DUO. - nohareAspirantActually I've just realised that I'm running the iTunesServer_1.0.2.bin update...not sure what 1.0.3 will do if I install it...... :?
- peterdgreenwayAspirantAll
I have got the new addon working fine on my ReadyNAS Pro but it will not work on my NV+ - any ideas ?
/var/log/mt-daapd.log has a stream of the following error lines when I try to connect using iTunes
[datetimestamp] Error (00008003): Error writing to client socket: Broken Pipe - SkywalkerNETGEAR ExpertThat's a low-level network connection error. Are all your other services working okay between those two clients?
