eastenders
Oct 09, 2014Aspirant
iTunes on Duo v2
Hi All I have successfully used this in the past with the add-on .bin file from mgm and had a few storage problems and ended up carrying out a Factory reset but no dramas This is my current scen...
eastenders
hi yes for sure no worries, new on the forum so will have to work it out, Can you attach a file?
Thanks again
Thanks again
