jukkaforss
Jun 27, 2019Tutor
kernel bug ReadyNASOS 6.10.1 screen massage __extent_writepsge_io+1d3
Hi, My Readynas hit kernel bug, it running latests code 6.10.1. Dmesg output after it happened. I needed to power cycle to get it rebooted. [1108355.142034] ------------[ cut here ]------------
[1...
- Jun 28, 2019
Shrinking this one down ...
jukkaforss wrote:
sdb part 1
root@readynas:~# smartctl -x /dev/sdb ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 159 9 Power_On_Hours -O--CK 028 028 000 - 52621 Error 9 [8] occurred at disk power-on lifetime: 50321 hours (2096 days + 17 hours) Error: UNC at LBA = 0x12fdf7710 = 5098141456 Error 8 [7] occurred at disk power-on lifetime: 50321 hours (2096 days + 17 hours) Error: WP at LBA = 0x12fdf7710 = 5098141456 Error 7 [6] occurred at disk power-on lifetime: 41988 hours (1749 days + 12 hours) Error: UNC at LBA = 0xcf083840 = 3473422400 Error 6 [5] occurred at disk power-on lifetime: 41988 hours (1749 days + 12 hours) Error: WP at LBA = 0xcf083840 = 3473422400 Error 5 [4] occurred at disk power-on lifetime: 38618 hours (1609 days + 2 hours) Error: UNC at LBA = 0xe824a0c0 = 3894714560 Error 4 [3] occurred at disk power-on lifetime: 38618 hours (1609 days + 2 hours) Error: WP at LBA = 0xe824a0b8 = 3894714552 Error 3 [2] occurred at disk power-on lifetime: 38618 hours (1609 days + 2 hours) Error: UNC at LBA = 0xe824a0b8 = 3894714552 Error 2 [1] occurred at disk power-on lifetime: 38615 hours (1608 days + 23 hours) Error: WP at LBA = 0x11616d4b8 = 4665562296
I saw a similar pattern on one of my WD60EFRX drives a while ago, and when I tested it with Lifeguard it failed. Though a second disk with the same pattern passed Lifeguard. So I recommend testing this disk (and perhaps replace it even if it does pass).
The most recent logged error was about 2000 hours ago (~ 3 months), so that particular error didn't cause the most recent crash. But I'm thinking that this disk likely triggered it anyway.
FWIW, I haven't seen any explanation of how to decode the raw read error rate. But it is quite a bit higher on this drive than your other ones.
- Mar 10, 2018Retired_Member
