dschwartzer
Jan 15, 2017Luminary
Larger Disks - No More Space
I have a RN526X running OS 6.6.1. I had two (2) 1TB Seagate drives in the unit using X-RAID. At that point, the system showed: data 133.79 GB Snapshots: 11.95 GB Free Space: 779.34 GB RAID ...
- Jan 15, 2017
O.K. Weirdly your root volume was showing up as having four disks not two. I fixed that.
The RAID had not expanded to use the additional space on the two disks so I manually triggered that. This may take an hour or two or so to complete.
Once that is done the volume should then expand automatically.
Anonymous
Jan 15, 2017Hi, could you send us the logs please?
dschwartzer
I've downloaded my logs and am trying to send them to you via a private message but I don't see a way to attach a file. Is there another way?
