dschwartzer
Jan 15, 2017Luminary
Larger Disks - No More Space
I have a RN526X running OS 6.6.1. I had two (2) 1TB Seagate drives in the unit using X-RAID. At that point, the system showed: data 133.79 GB Snapshots: 11.95 GB Free Space: 779.34 GB RAID ...
- Jan 15, 2017
O.K. Weirdly your root volume was showing up as having four disks not two. I fixed that.
The RAID had not expanded to use the additional space on the two disks so I manually triggered that. This may take an hour or two or so to complete.
Once that is done the volume should then expand automatically.
dschwartzer
HyacintheJ:
Finally found how to send logs via email. They have been send.
David
mdgm-ntgr
Jan 15, 2017NETGEAR Employee Retired
