AWAgentX's avatar
AWAgentX
LCD Lights staying on after 6.5.1 upgrade
So, two days ago I did the Readynas 6.5.1 upgrade and since then my lights on the front of the unit have been on solid (Netgear logo, Navigation ring, and OK button) they respond to my commands, but never turn off like they used to, is there a setting I need to change or is this a bug in 6.5.1?
Thanks for anyone's help!
  • Hello AWAgentX,
    Have you tried rebooting the NAS and see if you get the same results?
    If so, please contact support center to report that this happened after FW.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello AWAgentX,
    • AWAgentX's avatar
      AWAgentX
      Odd that it needed a second reboot after upgrade to make the lights go out...
ProSupport for Business
