atlgator
Aug 05, 2011Aspirant
Lion + Readynas Duo (beta) + Time Machine = FAIL??
Yohdah, I've been following all the blogs posts regarding Lion, AFP, and the Readynas Duo. What is unclear to me is if the two beta releases for the Duo have fixed Time Machine or not. For me it'...
pjc1
Aug 11, 2011Aspirant
@nyee: See my post above. You need to use the Time Machine service, or manually tweak the settings for your other shares in order to support Time Machine backups on them. There are special AFP features that are only enabled for the Time Machine service (by default). AFP works just fine for other shares for other purposes, just as you've described.
@salvobeta: I already replied to your other thread. You seem to be encountering a new problem.
@atlgator: That's weird that your computer isn't seeing the share on the network. Can you connect via afp://ReadyNAS@[server address]/? Does that make Time Machine happy? If so, then your issue would seem to be Bonjour/broadcast-related, and not specific to Time Machine.
