atlgator
Aug 05, 2011Aspirant
Lion + Readynas Duo (beta) + Time Machine = FAIL??
Yohdah, I've been following all the blogs posts regarding Lion, AFP, and the Readynas Duo. What is unclear to me is if the two beta releases for the Duo have fixed Time Machine or not. For me it'...
atlgator
Aug 24, 2011Aspirant
Skywalker wrote: You'll need to log in as "readynas", not "admin".
I tried that and I can see the sparsebundle. But I can't delete it. It tries for about 5 minutes and then says something about the token being in use. Tried 3 times with the same result.
UPDATE 1: Retrying the above with Time Machine unmounted... Will update in a few...
UPDATE 2: Checked this morning and sparsebundle failed to delete overnight. Retrying now. That thing takes FOREVER to delete. Is there a better way to remove than to select "Move to Trash"?
And to even try I have to keep restarting the Time Machine service. This thing is extremely unstable. It keeps dying repeatedly.
Is there anything else you recommend trying? It sounds like there's at least a few of us seeing this same issue. Very frustrating. My NAS drive is practically useless right now from my Macbook. It works just fine from my Win7 machine.
