atlgator
Aug 05, 2011Aspirant
Lion + Readynas Duo (beta) + Time Machine = FAIL??
Yohdah,
I've been following all the blogs posts regarding Lion, AFP, and the Readynas Duo. What is unclear to me is if the two beta releases for the Duo have fixed Time Machine or not. For me it's not working at all. I have the Time Machine service enabled on the Duo. But I can't see the Time Machine share from my Macbook in the Time Machine Preferences. It just doesn't see it. Furthermore, I have my AFP shares working again in Finder BUT, I had to explicitly mount them by IP address (i.e., afp://192.168.1.5, etc). In Snow Leopard my Duo's AFP shares were always located via Bonjour (I think). I could go to Networks and they would show up after it received advertisements. Now it never sees them unless I explicitly mount it. I'm assuming this might be why I can't see my Time Machine share as well.
So in summary, is Time Machine still broken for the Duo (and other Sparc NAS's)? Is the above behavior I described with AFPs shares not being advertised expected? If not, do you have any suggestions or help?
OS: MacOS Lion
NAS: Readynas Duo running 4.1.8-T9 beta
Thanks!
OS: MacOS Lion
Thanks!
- SkywalkerNETGEAR ExpertYou could also try mounting the "c" share using CIFS by logging in as "admin". If you enable viewing of hidden folders, you should see a .timemachine directory. I suppose it may work better to go this route instead.
- mdgm-ntgrNETGEAR Employee RetiredAlso once you've mounted the share rather than trying to delete using the Finder, go into the Terminal and try deleting it that way. The Finder can be notoriously slow at doing things.
- atlgatorAspirantWhen I got home from work the sparsebundle was finally deleted. We'll see how stable TM is now after it completes an initial backup cycle with a blank partition to work with.
- atlgatorAspirantI'm happy to report that so far erasing my entire old Time Machine sparsebundle and rebacking up my old Mac has now seemed to stabilize things with my Duo running the latest Beta. I'll keep a close eye on it but I can now run back to back Time Machine backups and it's now able to find the NAS unlike before. Previously it would die and I had to restart the Time Machine service. Now it's stable. So I don't know if that helps the ReadyNAS developers at all (I previously sent two of my logs), but something seemed to happen to the NAS Bonjour/TM stability after upgrading to the Beta (and/or Lion). My old TM backup image somehow caused issues. Now that I've started from scratch it appears to be reliable again so far. Seems like there are a few others out there with this same problem, so as a fellow embedded developer, where there's smoke there's probably fire. Seems like there's an issue somewhere, just might be a hard/weird one to track down. Please let me know if there's anything I can do to help.
- jhaleyAspirantIs there any eta on a production ready fix for the Lion/Duo problem. The wait is getting to be quite a PITA. I'm debating if it's worth rolling back to Snow Leopard or moving on to another NAS solution.
- EDCULAspirantI am so totally glad I ran a small test first
I am looking at getting a second ReadyNAS to be my time machine back up along with my first one as my media drive.
But after trying and reading I think I might get a ReadyNAS ultra4 pack it with drives and use it as both media and time machine.
