sanandros
Apr 30, 2019Aspirant
Looking for Ready NAS 6 Pro and NV+ CFIS replacment solution
So I have a Pro 6 and a NV+ but since Windows wants to be secured it doesn't allow this CFIS format any more. Now how can I use anyway these NASes in the Explorer with the other offered formats?
sanandros
May 06, 2019Aspirant
OK now i try to update the settings but I get allways an error message like the file is damaged or the volumes are not the same. I tried it with "All" and then I excludede the shares and the network and then at the end I tried it just with the access. Now just to test it I tried user and groups and it get's me an uknonwn server error.
May 07, 2019Guru - Experienced User
sanandros wrote:
Now just to test it I tried user and groups and it get's me an unknown server error.
Did you also check (after the error) if it had applied the configuration?
- sanandrosMay 07, 2019Aspirant
No nothing changed.
- StephenBMay 07, 2019Guru - Experienced User
Both these NAS are running OS 6? And both have the same data volume name?
sanandros wrote:
No nothing changed.
Likely you will need to re-do the config manually then.
No one has the old OS 4, I checked where they wrote any Volume name in OS4 but couln't find it.
