sanandros
Apr 30, 2019Aspirant
Looking for Ready NAS 6 Pro and NV+ CFIS replacment solution
So I have a Pro 6 and a NV+ but since Windows wants to be secured it doesn't allow this CFIS format any more. Now how can I use anyway these NASes in the Explorer with the other offered formats?
May 07, 2019Guru - Experienced User
sanandros wrote:
Now just to test it I tried user and groups and it get's me an unknown server error.
Did you also check (after the error) if it had applied the configuration?
sanandros
May 07, 2019Aspirant
No nothing changed.
- StephenBMay 07, 2019Guru - Experienced User
Both these NAS are running OS 6? And both have the same data volume name?
sanandros wrote:
No nothing changed.
Likely you will need to re-do the config manually then.
- sanandrosMay 07, 2019Aspirant
No one has the old OS 4, I checked where they wrote any Volume name in OS4 but couln't find it.
The volume name in OS 4 is "C".
More importantly, I understood your question to be how to migrate the configuration from one Pro running OS 6 to another Pro that was also running OS 6. You can't download from OS 4 and upload to OS 6.
