BernyB
Feb 22, 2017Tutor
Lost Replicate config
Hi, I've been doing Replicate over WAN from a RN316 (6.5.1) to a RN104 (6.5.2) forfew months. Few days agos I noticed that Replicate stopped because my email inbox was empty. I went back home an...
- AnonymousFeb 22, 2017
If you recreate the jobs with the same name and choose the correct destination (be careful not to nest them, so select the parent of the folder with the name of the job), it will restart from it stopped without restarting from scratch.
If you want to find out what the name of the job used to be, it's easy, it's the name of the folder that contains all the incremental folders.
If you want to double check after you started a job, browse the destination and you should see a 'in process' (or progress, can't remember) folder beside the folders of the previous occurrences (same parent).
BernyB
Feb 22, 2017Tutor
Thank you. It would be really nice to be able to backup the Replicate config.
Anonymous
Feb 22, 2017It would. You could post this as a suggestion in the idea section :)
