Jellen
Jul 24, 2020Aspirant
Lost volume after migration from RN314 to RN3138
Hi I wanted to migrate my data and volume from a Readynas RN314 to a new rackmount RN3138. Shut down both units, transferred the drives and kept the same drive order. After boot I was able to l...
- Jul 28, 2020
Hi Jellen,
This should be fixed now. Please check if you can now access your volume.
The OS was filled up so one of our L3 experts cleaned it. The problem could be the Docker because he saw that installed.
JohnCM_S
Jul 24, 2020NETGEAR Employee Retired
Hi Jellen,
Do you have a backup of your data?
Can you also download the logs the send it to me via private message? We will check what caused the issue. You may upload the logs to a file-sharing site then send me the download link.
- SandsharkJul 24, 2020Sensei
You didn't say you did, but I just want to verify that you did NOT export the volume (you shouldn't have).
Have you tried putting the drives back in the 314 and seeing what happens? Assuming the three drives you listed are all there is, you could try every combination of two and see if it'll boot with a degraded volume.
- JellenJul 25, 2020Aspirant
Hi Sandshark
No I din't export the volume. John is looking into the logs but looks like my volume has 2 devices. I'll keep you guys up to date.
Strange thing on the device my 3X 8TB Seagete disks show the Hard disk light continuos on, the one WD 3TB drive flickers. It's all one volume.
Thanks for the replies, keeping fingers crossed to recover the volume.
- StephenBJul 26, 2020Guru - Experienced User
If you vertically expanded the RN314 (upgrading to larger disks), then you have two RAID groups - md126 and md127 if you use XRAID. Those show up as two inactive volumes in the admin web ui when the volume can't be mounted.
