joe_wht
Jun 21, 2016Luminary
MacBook Pro Image Capture Auto-Import to ReadyNAS wont stick
2 weeks ago my 17" Macbook Pro DIED.. iphone AUTO-IMPORT to ReadyNAS pictures/autoimport worked PERFECT. .. Now.. with my tiny 15" Macbook Pro.. I've changed the auto-import Save to option to Rea...
BrianL2
Jun 23, 2016NETGEAR Employee Retired
Hi joe_wht,
I suppose you didn't use any app or software from NETGEAR. Try to check this article from Apple and tell us if it addresses your issue.
Kind regards,
BrianL
NETGEAR Community Team
joe_wht
Jun 23, 2016Luminary
No.. with my old Macbook Pro I used no app..
ONLY the macbook pro Image Capture - Auto Import check box & I selected the ReadyNAS folder for my
new photos to be uploaded when I connect my iphone to my mac. It just always worked perfect.
The apple iCloud article.. No.. I have to many pics & don't want to pay for Apple to hold them
and I'm not gonna delete any.
I TRIED to setup a ReadyNAS " Backup " but it seems the backup "test connection" can't connect to my new mac.
I was hoping to just let my MacBook pro to autoimport to it's OWN Auto Import folder
and then let ReadyNAS run a nightly Backup pulling them into my Photos "autoimport" folder.
I think there must be some permission that I have not found.
- BrianL2Jun 23, 2016NETGEAR Employee Retired
Hi joe_wht,
What if you mount the said share in your MAC via this article and select it as the path where your pictures will be automatically imported?
Kind regards,
BrianL
NETGEAR Community Team- joe_whtJun 23, 2016Luminary
You got my hopes up.. LoL.. but it Diid Not Work...
the past 3 hours I've been searching the internet
for anyway to :
" change image capture autoimporter to network "
and there's just No Suggestions.
how did it work so easy when I first got the ReadyNAS.
==== What if we try another approach..
===== What if I set ReadyNAS to copy the pictures/autoimport folder
====== on my Mac?
==== I can't get the ReadyNAS backup paths correct.
isn't the HOST field the ip address ? 192.168.1.28
which protocol? remote:windows/NAS timestamp is what's selected
share: what should go here ? ( I do have the autoimport folder shared )
Hi joe_wht,
I've sent you a PM. Update this thread once you've tried it.
Kind regards,
BrianL
