njordan
Dec 18, 2012Aspirant
Major issue. Fchk failed, Shares gone. Please help!
Hi, I recently expanded my NVX from 2x 1TB drives to 2x1TB and 2x2TB drives. Shortly thereafter one of the 1TB drives died and I replaced it with a 2TB drive. Everything was ok. The restriping and expansion all went smoothly but gave me a warning to do a file system check on next boot.
I ran the FS check which ran then failed sending me an email full of info (That I don't really know how to decipher) and a warning that the shares are unavailable. I ran the check again and it failed immediately. Now I can't access my data!
Is there anyone who can help? I can send whatever logs or that email with the data if it helps!
Thanks in advance!
Thanks in advance!
1 Reply
- njordanAspirantUp to level 3 tech support on this one. I'll try to post what the solution was if it isn't just done for me via telnet.
- Mar 31, 2022Anonymous
