yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
jarrah
May 30, 2008Aspirant
I only see the sparsebundle file, which has a disk image icon. There is also another file called ".<my_ethernet>" where <my_ethernet> is the same address I used in the sparsebundle.
What version of RAIDiator are you using? Are you using CIFS or AFP to mount the share?
