yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
jarrah
May 30, 2008Aspirant
Weird. It sounds like you might have mounted the sparsebundle on your machine and you're seeing inside it. When you say "a directory on the NAS", do you see the directory on the share volume that is mounted on your Mac?
I'd try removing the sparsebundle (or directory) from the share, unmounting the share, creating a new sparsebundle, remounting the share, copying it over, and then seeing if you can start a backup.
