yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
wardie
Jun 16, 2008Aspirant
stevesreed wrote:
It turns out the under 10.5.3, you are NOT supposed to mount the backup volume manually.
TM seems to mount the volume and then the sparsebundle all by it self now when I do "backup now".
If this helps, I can confirm that this works for me in 10.5.2 and 10.5.3 without the need for any manual mounting. I have two separate shares set up each with one sparsebundle, each backing up a separate Mac via TM, with no problems to date (about three months). Before TM has done its first backup since power on, it shows disconnected status, but then when it kicks off for the first time both the AFP share and the spareimage within it both get mounted for the duration of the backup.
