yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
Vatoe
Aug 02, 2008Aspirant
des wrote: So I faithfully followed the step by step instructions but...every time I get the same error:
Time Machine Error
The time machine image could not be created.
Help! Any thoughts?
Maybe this helps, as it sounds like the problem I was running into. :|
I thought I followed the instructions to the letter, then after several hours of frustration, I worked out that I wasn't naming the sparse bundle with the computer name, ie the one used to identify it over the network. One way you can find the name to identify the Mac, is in settings>network>highlight ethernet>click on advanced>WINS (its the netbios name).
So in the instructions where it says you can name the 'volume' anything it's not actually referring to the naming of the sparsebundle itself. The naming of the sparsebundle is the product of 'networkcomputername'+'ethernetmac address'.sparsebundle). After I made this change to the naming of the sparsebundle, it all works very well.
