yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
mcgroarty1
Aug 02, 2008Aspirant
yoh-dah wrote: The step-by-step how-to can be found here.
I believe that's going to default to 1 meg span sizes, or 1024 files per gig of backup.
Try adding this:
-imagekey sparse-band-size=131072
That makes it allocate 64 meg blocks (131072 * 512 byte sectors = 64m), for 16 files per gig of backup. This saves space and helps performance.
Edit: btw, the Time Capsule defaults to 8 meg blocks. I suspect it would use larger if the thing weren't so tight on RAM.
