yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
myuill
Aug 03, 2008Aspirant
Just an FYI in case anyone runs into the same problem I did. TM backups were working for a few months then started failing.
Turns out the sparesbundle I created was too small. Even though my hard drive is 185 GB, it was "full" even though my hard drive wasn't (it was about 179 GB). I made a sparesbundle that was 200GB in size, still wasn't good enough so I went up to 220 GB and now it works like a charm.
So if you get failures ... try making your sparesbunldle bigger.
