yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
Avi_Drissman
Aug 17, 2008Aspirant
I've had to do it, and what you do is boot from the install DVD and pop a terminal window. Then you get to mount your backup drive from the command line:
$ mkdir /Volumes/backup
$ mount_afp afp://username:password@nasaddr/backupvolname /Volumes/backup
or so (I'm typing this straight from memory). Then quit the terminal, go back to disk restore, and pick the drive.
Avi
Avi
