yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
hknas1
Dec 18, 2008Aspirant
I'm not a mac guru so someone else may provide better advice.
you probably aren't granting the proper write permissions.
from a terminal window if you go to
cd /var
and type
ls -ltr
look at the permissions for db
mine is:
drwxr-xr-x@ 42 root wheel 1428 Dec 18 18:53 db/
if the same you may need to open up the permissions. If you need help with that ask.
fyi if you then go cd db
ls -a .T*
you can see the Time machine files.
-rwx------ 1 root wheel 16 May 1 2008 .TimeMachine.Cookie*
-rw-r--r-- 1 root wheel 1099 Dec 18 18:53 .TimeMachine.Results.plist
no clue if this will help but if you show your permissions that would help towards figuring it out.
cd /var
and type
ls -ltr
mine is:
ls -a .T*
