yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
pboulo_gmail_co
Dec 18, 2008Aspirant
cd on the mac to /var/db
sudo rm .TimeMachine.*
then return to TM perefences and you should be able to set this up.
Also to remove a previous setup I removed /Library/Prefernces/com.apple.TimeMachine.plist This did not fix the fail to create /var/db/.TimeMachine.Cookie but removing the orignal cookie files did...
