yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
Blues11
Feb 10, 2009Luminary
What happens when you boot from your OS X DVD? If it doesn't allow you to connect to the ReadyNAS I don't know if restoring your Mac's hard drive is possible directly from the ReadyNAS. However, you might be able to copy the file where you were doing your TM backups (the sparsebundle file) to an external drive that you can connect via Firewire. Then you ought to be able to restore the hard drive from that image.
I don't have any knowledge about restoring from one version of the MBA to another. If there are actual hardware differences between the two machines the restore may not work either at all or properly. But first things first. See if you can get the drive restored. (FWIW, I've done it from an external Firewire drive and it worked perfectly.)
Good luck.
Good luck.
