yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
sirozha
Feb 18, 2009Aspirant
bollar wrote:
sirozha wrote: So, the document off Apple.com (http://support.apple.com/kb/HT1177) that explains how to restore from a Time Machine backup housed on Time Capsule has a section on "restoring the entire volume that was erased". Has anyone tried that with the ReadyNAS. Is this something that is possible with the new ReadyNAS firmware, which officially supports Time Machine backups?
Yes, that's what I did, but you'll note that it requires the Leopard DVD and the OS will be loaded off the DVD and not the Time Machine backup.
Forgive my ignorance, but from the description in that document, it appears that you have to boot up with the installation DVD, but you don't really install the OS from the installation DVD. All you do is point to the location of the Time Machine backup, and if you are accessing Time Capsule over Wi-Fi, you need to configure your wireless network SSID and password for Time Capsule to become accessible. The instructions don't say anything about having first to install the OS when restoring the entire volume that was erased. So, I was under the impression that the Time Machine backup already contains the OS, and this type of restore can pull the entire backup from Time Capsule (aka ReadyNAS) and thus copy the OS, the applications along with their settings, and all user files from Time Capsule to the newly installed hard drive.
