yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
bollar
Feb 18, 2009Aspirant
sphardy wrote:
<Beware - rant mode on>
It seems like you've done a good job enumerating the limitations of Time Machine / Time Capsule. Certainly most of the issues you note with the ReadyNAS are directly because of the way Time Capsule was designed. If there's a way to make something better than TC, I do think that would be cool, but given the closed nature of the solution, I believe it will be difficult to do that, while still using TM. (i.e., I think the improved solution would look something more like Retrospect or Synchronize Pro X.
