yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
sphardy1
Feb 27, 2009Apprentice
dtambre wrote: other then when the system is backing up does anyone know of a way to get into the external drive that shows up?
If you setup TM with the NAS manually (ie do not use the service in the newest 4.1.5 beta) then you can simply mount the TM backup by double-clicking on the sparsebundle in finder
dtambre wrote: Because I know I can defiantly root through the backups.db folder and get rid of old dates manually should the need arise. And if I remove files from there does anyone know if it effects the sparsebundle size in return? Or does the sparsebundle stay bloated?
It stays bloated - this I can confirm from practical experience
