yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
rupert1020
Apr 06, 2009Tutor
dtambre wrote: In theory (ie I don't knwo of anyone who has tested this) the sparsebundle will only be restricted by the available space on your NAS - I'm not aware of any size limitations of sparsebundles.
I think the sparsebundle can also be limited by the size you attribute when creating it. An easy way to expand the sparsebundle is to mount the TM share, then drag the SP onto disk utility. From there you can fix it and / or expand it.
