yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
theho
Jan 06, 2010Aspirant
Greetings fellow ReadyNAS Users...
I have a brand new 2110 and want to use TM to back up my iMac. Followed the instructions, and it worked like a charm.
Then, I changed the connection from my iMac to the router from ethernet to (very fast) wlan. Since then, the data transfer speed of TM, and TM only, has reduced to bytes per second (has been running for about 15 minutes now and transferred 46KB (!). Other file transfers to the ReadyNAS via finder etc work just fine.
I want to use the backup facility without the ethernet cable, but at this speed it is clearly not an option. Something is wrong. Any suggestions as to what that might be?
Any suggestions?
Any suggestions?
