yoh-dah
Apr 21, 2008Guide
Making Time Machine work with the ReadyNAS
The step-by-step how-to can be found here.
- 0deuce0AspirantJust FYI for everyone... Im running time machine on my NAS box... and I lost a hard drive. Apple replaced it and I restored the files via time machine with no issues! whew!
tom - yoh-dahGuide
0deuce0 wrote: Just FYI for everyone... Im running time machine on my NAS box... and I lost a hard drive. Apple replaced it and I restored the files via time machine with no issues! whew!
tom
Sure sounds like you should be doing a testimonial ;-) - btaroliProdigy
Did you have to do the usual workarounds in order to mount a network volume while booting from the DVD? I haven't tried this kind of bare metal restore yet, so I'm curious about the steps you had to go through. - teerukuAspirantWhat is the difference of me having this setting
defaults write com.apple.systempreferences TMShowUnsupportedNetworkVolumes 1
and the manual process listed here ? - sphardy1Apprenticeteeruku,
By default TM will not show network volumes for selection when specifying the backup volume - this setting enables that feature so that TM can back up to a NAS device rather than just an external drive / Time Capsule etc
It is disabled by default as Apple do not support this functionality
///P - btaroliProdigy
teeruku wrote: What is the difference of me having this setting defaults write com.apple.systempreferences TMShowUnsupportedNetworkVolumes 1
On later 10.5.x releases (starting with 10.5.3 IIRC) that option no longer needs to be set.
What *did* happen, unfortunately, is that a bug was introduced that prevented the automatic creation of the backup volume (in 10.5.3 IIRC)... hence the creation of the "manual" process you refer to. - btaroliProdigy
sphardy wrote: teeruku,
///P
This is no longer true with later 10.5.x releases. I haven't had this option set in my installation since 10.5.3, and i'm on 10.5.4 now. TM is working like a champ. - sphardy1Apprenticebtaroli
I have found this to not be the case - I have recently had issues with a hard drive that has caused me to setup TM multiple times under both 10.5.3 and 10.5.4. In all cases I needed to set the preference before I could use a NAS volume
///P - Meob1AspirantI am not 100% sure about this, but the T120 code is the only change in the topology,
can anyone else confirm if their time machine backups are still working?
I got a error saying there was not enough space on the NAS when there are x00's free... - Meob1Aspirantturns out my sparsebundle / backup size limit was too small i think.
I set it to 140g, just checked its current size on the nas = 138gig
what was weird was that the time machien error said it needed a extra 40 gig and there was only 60 gig left???
(there is over 200 gig free??? weird...)
re-did all the steps in the how-to and set it to 180 gig
looks like I am backing up from scratch again now tho ;-(
ah well - live & learn!
