Michael_Oz
Jan 08, 2013Luminary
Many security_mode=share issues here, what's the problem?
With Security Mode=share, people are having issues with new, non passworded shares, where Windows (7 & Vista & I think XP) asks for a userid/password for what should be an open/guest access. Seems ...
Michael_Oz
Jan 28, 2013Luminary
I have been dealing with support re this.
I replied that what would be better would be to find what is incorrectly putting the "D" there and fixing it.
In the mean time, if you want to use 'Share' mode go back to 4.1.8.
I'm holding my breath...
Please see the latest update from L3 Engineer:
I debugged this issue again in 4.1.10 yesterday. After ReadyNAS firmware upgrade from 4.1.8 to 4.1.10, the samba model also upgrade from 3.0.37 to 3.5.16. If user created a new share when NAS run firmware 4.1.10, it would add a new property for the share.
Below is the key information:
nas-06-3F-A6:/etc/samba# cat smbpasswd
test-4.1.8:1003:NO PASSWORDXXXXXXXXXXXXXXXXXXXXX:NO PASSWORDXXXXXXXXXXXXXXXXXXXXX:[NU ]:LCT-00000000:
test-4.1.10:1004:NO PASSWORDXXXXXXXXXXXXXXXXXXXXX:NO PASSWORDXXXXXXXXXXXXXXXXXXXXX:[NDU ]:LCT-00000000: # which means samba disallow user access this share.
If you edit this configuration file delete parameter “D”, restart the samba, then it would be access without password.
I did not know whether this is samba 3.5.16 issue or our NAS FrontView issue. My colleague told me the NAS and Samba 3.5.16 has some compatibility issue when it worked “Share” mode. Our recommend solution is changed to “User” mode, and most of our user accepted our suggestion.
I am sorry I give you unclear information, because the ReadyNAS NV+ 4.1.10 is stable firmware, I did not know when we will release a new firmware, so I give you a unclear feedback.
Now there are 2 solutions:
1. Changed to “User” mode,
2. Edit the /etc/samba/smbpasswd configuration file and delete the parameter “D”, then it would be worked.
- Question: Why the share be create in 4.1.8 can be access without password?
- Answer: because when NAS worked in 4.1.8, and user create a share, it has not parameter “D”, so it can be work.
