firerain
Sep 23, 2016Tutor
Max input voltage for RNDU2000
Hi there! I'm trying to find some info about max input voltage for RNDU2000 (and not only this one, I assume). I'd like to connect it with a buffer power supply which outputs 13.8V at default. Of c...
- Sep 24, 2016
Design spec is 12V +/- 5%. On-board DC-DC circuits typically work within +/- 20% range.
BUT: 12V to hard drive is unregulated(except very low voltage drop switch), please check your hard drive 12V rating (typically +/- 10%). So 13.8V is a little over hard drive 12V rating.
c3po
Sep 24, 2016NETGEAR Expert
