Coloriti1
Jul 09, 2011Aspirant
Maximum memory on Ultra series
What would be the maximum memory supported on Ultra 4? I am looking to upgrade with Kingston KVR800D2N6/2G . According to some Forum posts this stick is compatible with Pro series.
PapaBear1
Aug 15, 2011Apprentice
My advice to anyone upgrading the memory of a computing device is to take the memory module that is working and came with the device and match the specs except for size. Pay close attention to the CL/timing value and voltage as well. But, even that is not a guarantee of success as some manufacturers make changes under the hood and don't change the model numbers. You would be well advised to run the memory test several times after changing the memory.
