olsenn
Dec 13, 2011Aspirant
Maximum Path length? Input/Output errors
I am repeatedly getting errors while running a backup job to from the ReadyNas Duo to a file server. Most of the files backed up properly, however I am now (daily) getting error messages such as: ...
ReadySECURE
Apr 10, 2012Apprentice
The particular length that StephenB would be referring to is due to Windows limitations. The ReadyNAS will look at it in the term of bytes. 255 bytes would be the cut-off point if I recall correctly.
