xymox
Jul 30, 2013Aspirant
Memory upgrade (Ultra 4 & NVX Pioneer Edition)
Hello, Been searching the forum a bit, but couldn't fint any specific information about memory-upgrade to the Ultra 4 & the NVX Pioneer Edition. Both my machines has 1GB installed out of the box...
mdgm-ntgr
Jul 30, 2013NETGEAR Employee Retired
Take a look at http://www.readynas.com/forum/viewforum.php?f=110
It's possible that modules others have found to be compatible years ago may have a newer version that is not compatible.
The NVX and NVX Pioneer have the same hardware as each other.
Unless you are running lots of add-ons or some memory intensive ones you will likely see little benefit from using more memory.
