skwiggly
Feb 03, 2026Tutor
Messed up trying to upgrade drives, help!
Hi, I could use some help upgrading the drives in my ReadyNAS RN212. I had 2 Seagate 6TB drives in RAID1, and wanted to upgrade to 2 12TB drives. I don't think I followed the correct procedure in doi...
- Feb 04, 2026
Your procedure was the correct one.
I'd start by testing the two new drives in a Windows PC using Seatools. I always start with the non-destructive full test, and follow up with the full write-zeros test. That will take awhile (perhaps one day per drive) - but it will give some assurance that both disks are ok. I have purchased some drives that passed one of these tests out of the box, but failed the other. You can connect the drives with directly with SATA (assuming a desktop PC) or get a USB-SATA dock.
Assuming the drives pass, then boot up the NAS with only the 6 TB drive installed in slot 2. Then hot-insert one of the (now blank) 12 TB drives in slot 1. That should resync.
Once you are sure the resync has completed, you can then try hot-swapping drive 2 again.
skwiggly wrote:
However, when powered back up, and accessed the web dashboard, I saw that the drives were now re-syncing, which I did not want since 12TB #2 had already synced.
Likely disk 1 was being resynced to disk 2. Probably not an error, and interrupting that sync explains why disk 1 is now red.
One thing you should do for extra data safety is to connect the 6 TB drive from slot 1 to a PC and format it there. Then copy your data to that drive over the network. You have no redundancy at the moment, so any problems with drive 2 will result in data loss.
