JosephAE
Aug 25, 2015Tutor
Method to Recover Deleted Files on ReadyNAS Pro
How would I undelete a file that I just deleted on my ReadyNAS Pro?
- Sep 28, 2015
Hi JosephAE,
Sad to say that the data that you accidentally deleted are no longer recoverable since the features I mentioned weren't enabled when it happened. You may want to try with any 3rd party data recovery company to check if the said files can still be recovered.
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Aug 25, 2015NETGEAR Employee Retired
Hi JosephAE,
If you have enabled Recycle bin on the share or snapshot, there's a chance you can recover the said file.
Kind regards,
BrianL
NETGEAR Community
- JosephAESep 14, 2015Tutor
Sorry for the delay BrianL but I was out of town and didn't have access to my messages.
What would be the first thing that i need to do? I shut down the machine imedialy after I carelessly deleted the file hoping the file wouldn't be written over by another action. Do I need a special software?
- BrianL2Sep 14, 2015NETGEAR Employee Retired
Hi JosephAE,
Can you confirm if Recycle Bin and Snapshot are both enabled before the files was accidentally deleted? Could you also tell us the Firmware installed in your ReadyNAS system.
I look forward to your response.
Kind regards,
BrianL
NETGEAR Community
