JosephAE
Aug 25, 2015Tutor
Method to Recover Deleted Files on ReadyNAS Pro
How would I undelete a file that I just deleted on my ReadyNAS Pro?
- Sep 28, 2015
Hi JosephAE,
Sad to say that the data that you accidentally deleted are no longer recoverable since the features I mentioned weren't enabled when it happened. You may want to try with any 3rd party data recovery company to check if the said files can still be recovered.
Kind regards,
BrianL
NETGEAR Community Team
JosephAE
Sep 15, 2015Tutor
I will check when I return later this week. Thanks for the help.
BrianL2
Sep 15, 2015NETGEAR Employee Retired
Hi JosephAE,
Alright. Just keep us posted.
Kind regards,
BrianL
NETGEAR Community
- JosephAESep 27, 2015Tutor
Thanks for the help. I'm back with the ReadyNAS for a few days so here is the data you requested.
ReadyNAS Pro Business
Firmware 4.2.27
I don't think Recycling Bin was enabled for that Share.
Snapshot was off.- BrianL2Sep 28, 2015NETGEAR Employee Retired
Hi JosephAE,
Kind regards,
BrianL
