kevmattone
Aug 21, 2018Aspirant
Migrate from dead ReadyNASRNDP6000v2 (ReadyNAS Pro 6) to another
Hi all,
I have a ReadyNas Pro 6 that died a few days ago (will not power on). I do not want to lose the data on these drives. I see two options; replace the PSU or get the disks working in anot...
- Aug 21, 2018
Hi @kevinattone
Welcome to the Community!
There shouldn't be any issues placing the disks on your spare Pro 6. However, since it has been in use it's firmware might be outdated than the one that broke down.
I would advised inserting a spare disk to set it up and then make sure it's firmware is updated or has the same firmware with the one you have used then you just need to make sure you nsert the disks in the same order.
It should boot normally since it has the same OS and architecture. Other members might also have other advise on how to do it but there shouldn't be any issue swapping the disks out. You're right swapping the PSU will put in more work but it's another option.
Regards
Marc_V
Aug 21, 2018NETGEAR Employee Retired
Hi @kevinattone
Regards
- kevmattoneAug 21, 2018Aspirant
Hi Marc,
Thanks for the reply. Unfortunately, I don't know the firmware version on the dead unit. Once the firmware on the working unit is up-to-date, will that suffice? Also, is there any risk that the new unit will try to rebuild the RAID array or do anything to compromise data integrity? I would rather retain the data on these drives than get a quick-fix.
Thanks again,
Kevin
- StephenBAug 21, 2018Guru - Experienced User
Just update the firmware to the current firmware before you migrate the disks.
If the power failure also resulted in an out-of-sync array, then it will attempt to resync it. It will also do a file system scan on the volume when you boot it. Note this would also happen if you repaired your current pro.
You can skip the volume scan - there is a boot menu option which does that.
It is possible to prevent the system from re-syncing the RAID array, but I don't recommend doing that unless you are going to do an immediate full backup of the system after it boots.
- mdgm-ntgrAug 21, 2018NETGEAR Employee Retired
We did design the process of migrating disks across to work as smoothly as possible, however it's not a replacement for backing up your data. In future I would suggest that you backup data that you don't want to lose.
