gonzonia
Aug 12, 2016Aspirant
Mimic "Set ownership and permission for ...." in cron?
I previously posted an issue I was having with Backup errors https://community.netgear.com/t5/Using-your-ReadyNAS/Backup-FROM-ReadyNAS-NVX-to-OSX-with-NFS/m-p/1099388 I find now that whene...
- Aug 12, 2016
If you run top and use the "c" toggle you can see that the commands are chown -R user:group /c/sharename and chmod -R xxx /c/sharename (xxx being determined by the permissions you set).
This still seems like the wrong solution to me. Why not just create a matching group on the mac? or reset the GID for staff?
gonzonia
I know I'm using a consistent credential on the Macs. The issue seems to be with the group id. The default when creating a file on the ReadyNAS is 103 (Gods). The default on the Mac is 20 (staff).
When the backup job happens from the ReadyNas to another Mac using Remote NFS (I tried Windows/NAS and couldn't get the connection to work) , the system attempts to preserve ownership. This fails because of the group owner of the files that have been added.
If I run the "Set ownership and permission for existing files and folders in this share to the above settings." where the group id is the group on the ReadyNAS with an id of 20 it fixes the problem.
This is why I'd like to just have a way to automate whatever command that uses. I just need to know what command it is running. I'm sure it's a chown but I'd like to know the exact paramaters so nothing else gets broken.
Aug 12, 2016Guru - Experienced User
