Remoh11
Jan 16, 2020Aspirant
Missing storage & Time Machine
Model: ReadyNAS Duo [X-RAID] Serial: 24M3117L00DCB Firmware: RAIDiator 4.1.16 [1.00a043] Memory: 256 MB [2.5-3-3-7] IPv4 address:: 192.168.1.69 Volume C: Online, X-RAID, 2 di...
- Jan 17, 2020
well it took multiple attempts to delete them but it has work and I now have 1.37TB available after turning the TM bck on via front view and logging in as ReadyNAS and then deleting the sparse bundles. Now creating new backups, thank you forr all your help
Jan 16, 2020Guru - Experienced User
Remoh11 wrote:
I have tried accessing the Readynas and it shows a share that that isn't shown on the readynas list of shares
How have you tried accessing it, and what is the name of the share that isn't on the share list?
Also, are you wanting to delete the time machine backups, or do you just want to figure out where the space is going?
- Remoh11Jan 16, 2020Aspirant
I have been accessing it via Finder on my mac although I am struggling to get that to connect now. I have installed root ssh but haven't used that yet as I need to find out how to use it.
I have also used front view
What I am trying to do is remove all old TM back ups and a share called Richard which doesn't show in front view. I then want to switch TM back on and start again. I also have to shares that are activ that I wish to keep
- StephenBJan 16, 2020Guru - Experienced User
Is there a NAS user account called Richard? If so, this is a "home" share that only shows up when you access the NAS with Richard's credentials.
If that's the issue, there is a setting to disable home shares for all NAS accounts. See pages 13-32 here: http://www.downloads.netgear.com/files/GDC/RND2110/RAIDiator4-1_SW_en_06Dec11.pdf
Did you try disabling Time Machine Support in the NAS?
- Remoh11Jan 17, 2020Aspirant
thanks I have realised that its the home share as I managed to get in via finder as admin and saw the the three home shares.
I have disabled TM on the readynas front view and rebooted it but I am still missing about 460GB. I have added up the reported size of all directories plus the available space and it come to around 1.4 TB and the total available is 1.86tb its the missing 0.46TB I just cannot find
