Remoh11
Jan 16, 2020Aspirant
Missing storage & Time Machine
Model: ReadyNAS Duo [X-RAID] Serial: 24M3117L00DCB Firmware: RAIDiator 4.1.16 [1.00a043] Memory: 256 MB [2.5-3-3-7] IPv4 address:: 192.168.1.69 Volume C: Online, X-RAID, 2 di...
- Jan 17, 2020
well it took multiple attempts to delete them but it has work and I now have 1.37TB available after turning the TM bck on via front view and logging in as ReadyNAS and then deleting the sparse bundles. Now creating new backups, thank you forr all your help
Remoh11
Jan 17, 2020Aspirant
thanks for all your help. Couldn't find the the .timemachine folder but have found that if I turn ttimemachine support back on via frontview I can log onto the server in finder as ReadyNAS and se the sparse bundles so I am going to delete those and see if that helps.
Then I will try to find out how to set the NAS recycle bin to see if that is turned on
Remoh11
