pgjscottieuk
Mar 13, 2017Guide
Missing Storage Readynas 516
I am running my 516 nas with 6 x 4TB hard drives = 24TB in XRAID RAID 5 My NAS tells me i have 10.11TB Free Space Used Data 4.33TB i thought 24TB's in Raid 5 would give me 20TB space I started of w...
- Mar 14, 2017
After a Resync the volume has now expanded showing correct size 18.07TB instead of 14.43
pgjscottieuk
Mar 13, 2017Guide
How do i download the logfiles
Mar 13, 2017Guru - Experienced User
If you purchased new between 1 June 2014 and 31 May 2016, then you have lifetime (free) chat support. If you have it, then you should use it - see my.netgear.com
There's a download control on the log page in the web ui. That will download the full log zipfile.
Your volume appears to be 4 TB short. There are three possibilities.
- You could be running dual redundancy
- The btrfs volume might not have expanded when the last disk was added (even if all disks are in the RAID array).
- One disk might not be part of the active RAID array (despite the status shown in your screenshot)..
In the last case, one of the disks might be marked as a "spare" in the logs. Try looking through btrfs.log, mdstat.log and volume.log.
- pgjscottieukMar 14, 2017Guide
Have looked through the files you have mentioned cant find anything suggesting a spare have attached thanks again for help
There did seem to be a spare at the end of the mdstat.log number 3 ?
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md127 : active raid5 sde3[0] sdc3[3](S) sda3[5] sdb3[4] sdd3[2] sdf3[1] 15608666624 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/5] [UUUUU] md1 : active raid6 sdc2[0] sda2[5] sdb2[4] sdf2[3] sde2[2] sdd2[1] 2093056 blocks super 1.2 level 6, 512k chunk, algorithm 2 [6/6] [UUUUUU] md0 : active raid1 sde1[0] sda1[5] sdb1[4] sdc1[3] sdd1[2] sdf1[1] 4192192 blocks super 1.2 [6/6] [UUUUUU] unused devices: <none> /dev/md/0: Version : 1.2 Creation Time : Thu Feb 19 15:00:27 2015 Raid Level : raid1 Array Size : 4192192 (4.00 GiB 4.29 GB) Used Dev Size : 4192192 (4.00 GiB 4.29 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Mon Mar 13 21:05:10 2017 State : clean Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Name : 7c6e3734:0 (local to host 7c6e3734) UUID : c1aecbdd:0f2a5130:71ba0480:07a324f5 Events : 1139 Number Major Minor RaidDevice State 0 8 65 0 active sync /dev/sde1 1 8 81 1 active sync /dev/sdf1 2 8 49 2 active sync /dev/sdd1 3 8 33 3 active sync /dev/sdc1 4 8 17 4 active sync /dev/sdb1 5 8 1 5 active sync /dev/sda1 /dev/md/1: Version : 1.2 Creation Time : Sat Sep 24 11:40:47 2016 Raid Level : raid6 Array Size : 2093056 (2044.00 MiB 2143.29 MB) Used Dev Size : 523264 (511.00 MiB 535.82 MB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Thu Mar 9 17:35:17 2017 State : clean Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 512K Name : 7c6e3734:1 (local to host 7c6e3734) UUID : 39ce8693:bda6cd12:2a906266:c669f6f5 Events : 19 Number Major Minor RaidDevice State 0 8 34 0 active sync /dev/sdc2 1 8 50 1 active sync /dev/sdd2 2 8 66 2 active sync /dev/sde2 3 8 82 3 active sync /dev/sdf2 4 8 18 4 active sync /dev/sdb2 5 8 2 5 active sync /dev/sda2 /dev/md/data-0: Version : 1.2 Creation Time : Thu Feb 19 15:00:27 2015 Raid Level : raid5 Array Size : 15608666624 (14885.58 GiB 15983.27 GB) Used Dev Size : 3902166656 (3721.40 GiB 3995.82 GB) Raid Devices : 5 Total Devices : 6 Persistence : Superblock is persistent Update Time : Mon Mar 13 21:04:44 2017 State : clean Active Devices : 5 Working Devices : 6 Failed Devices : 0 Spare Devices : 1 Layout : left-symmetric Chunk Size : 64K Name : 7c6e3734:data-0 (local to host 7c6e3734) UUID : 2fb715d8:4a24e72b:57e364dc:cda58209 Events : 22927 Number Major Minor RaidDevice State 0 8 67 0 active sync /dev/sde3 1 8 83 1 active sync /dev/sdf3 2 8 51 2 active sync /dev/sdd3 4 8 19 3 active sync /dev/sdb3 5 8 3 4 active sync /dev/sda3 3 8 35 - spare /dev/sdc3
- mdgm-ntgrMar 14, 2017NETGEAR Employee Retired
Yes, one of the disks has been marked as a spare.
It's also clear that your volume was created on very old firmware.- pgjscottieukMar 14, 2017Guide
Hi hope you received the 5 digit code that you requested
You say it was set up on very old firmware the unit was purchased in Feb 2015 and i followed the setup procedure as instructed
I check on a regular basis the update button to try and make sure its as current as possible
A resync should be taking place now. Once that completes the volume should then expand automatically.
Thank you as soon as it finnishes will update it has about 14 hours to go
Before coming on to the community site i had tried to find the Resync facilty as i had that train of thought
