pgjscottieuk
Mar 13, 2017Guide
Missing Storage Readynas 516
I am running my 516 nas with 6 x 4TB hard drives = 24TB in XRAID RAID 5 My NAS tells me i have 10.11TB Free Space Used Data 4.33TB i thought 24TB's in Raid 5 would give me 20TB space I started of w...
- Mar 14, 2017
After a Resync the volume has now expanded showing correct size 18.07TB instead of 14.43
Fishbones
Mar 17, 2017Tutor
OK. I presume sde is Disk 5... I'll replace the disk and see if it resyncs to full capacity.
jak0lantash
Mar 17, 2017Mentor
No no, the issue is not with the hard drive. It's not a physical issue. Sde4 is "just" a partition, that is a RAID member. You have to fix the RAID.
I'd grow md126 to 6 devices, and remove / add sde4 if necessary (using mdadm).
- FishbonesMar 17, 2017Tutor
So somehow OS6 messed up the X-RAID expansion :smileyfrustrated:
Should there not be only a md126? Why the md127?
I'm not familiar with "mdadm" and RAID. So I'll probably have to backup (painfull) and do a factory reset.
Thanks for the tips.
BR.
- jak0lantashMar 17, 2017Mentor
In your situation, it's normal that there is md127 and md126.
- mdgm-ntgrMar 17, 2017NETGEAR Employee Retired
I can fix this easily. I've sent you a PM.
When you vertically expand your data volume (expand by adding higher capacity disks) it will create another RAID layer. So rather than just having a md127 you'll have a md126 as well.
It is resyncing.
- FishbonesMar 18, 2017Tutor
Fixed here too :smileyvery-happy:
After resync the volume has now corrrectly expanded to 9.07TiB
Thank You!!!
