marcus2
Oct 15, 2011Aspirant
mkfs.ext4 command parameters for 16tb+ volumes
On my ReadyNAS Pro recently, I had a problem with vertical expansion failing to work after replacing two drives with 3tb discs. After consulting over the course of a few weeks with support and findin...
marcus2
Oct 18, 2011Aspirant
FYI - I tried searching the filesystem for tools using the mkfs command, and I found one of the Frontview compiled Perl modules did so...but couldn't derive parameters from it (and it might just be for USB-attached drives instead of the primary array).
If there is something I could call from the command line to invoke the standard ReadyNAS modules/code to do this, all the better....
Any ideas? Thanks!
Any ideas? Thanks!
