Zaim
Jan 23, 2013Aspirant
MKV showing as MPEG via DLNA
Hi, I purchased the Netgear NV+V2 NAS, I have copied a few MKV's and M2TS files to test it works via my Sony BDP 490, now the MKV files wont play, interestingly these files show up as MPEG on the blu-...
Jan 23, 2013Guru - Experienced User
The playback issue is almost certainly in readydlna. Do you know if the mkv uses header compression?
It shows up as mpeg because readydlna is exporting them as mpeg - so that in itself is not the problem.
